paullac
Jun 26, 2015Explorer
TPMS / TST507 Questions
I just picked up & installed a TST 507 TPMS.
For others that have that system, I have a couple questions:
- How much do the tire pressure readings move around? It seems like they generally change from one reading to the next reading in the cycle. It's generally about 1 lb at a time. But it could vary as much as 2 to 3 (or maybe even 4) lbs over the course of an hour. It seems like it adjusts with the outside temperature & tire temperature.
- Also, does it seem like the tire pressure readings are right on, a little high, or a little low? In my case, I have an old fashioned tire gauge & cheapie air compressor that both show readings that are maybe 3 - 5 lbs higher than the TST readings.
Thanks!
Thanks!
