conceptumator wrote:
Occasionally lose the reading from the left rear sensor on the toad (farthest away) but that's not really been a big enough issue to spur me into buying and installing the extender.
When your TST monitor alerts you to a sensor's lost signal (i.e. it beeps and the readings go blank on the monitor for that sensor), that actually means that the monitor has been looking for a signal for up to an hour and has then given up trying to find it.
Several of us with TST systems have tested this and found it to be the case.
TST is aware of the situation and has confirmed this.
Nothing against TST....that's just how the system is. You may want to consider a signal booster/repeater.
