conceptumator wrote:
I bought the TST507 to replace the piece of **** TireDawg model I originally had. Much better performance! Got the flow through sensors for the coach and the non-flow through for the toad so they didn't stick out as far. The coach is right at 40' and I read everything without the range extender. Occasionally lose the reading from the left rear sensor on the toad (farthest away) but that's not really been a big enough issue to spur me into buying and installing the extender.
As long as you are aware that you may not have had up to date readings from that tire for as long as one hour. A lot can happen in one hour.
