BB_TX
Apr 23, 2015Nomad
The are 3-4 brands that get pretty good reviews, TST 507 being the most popular it seems. That is what I have and very happy with it.
The TST 507 has user replaceable batterys. And you can get either standard sensors, or flow thru sensors that allow you to add/remove air without removing the sensors. But some have said that adding air thru the flow thru sensor is so slow it is easier to take them off if you need more than a few pounds of air. I have the standard sensors, and since I only need to add 2-3 lbs air in the spring and am good for the season, the standard ones work fine for me. The flow thru sensors are also larger and heavier.
38,778 PostsLatest Activity: Jun 10, 2026
