rbp111's avatar
rbp111
tpms vs tire gauge reading
I purchased two things for the trailer. One was a tire gauge and the other was the Tire Pressure Monitor System.
First, I checked the pressure by use of the gauge (brand new). The tire pressure showed 110 PSI. After that, I installed a TPMS and noted that the Tire pressure was showing 115 psi (cold pressure). As the tire is used and the day increases in heat, the tire was showing 123 psi.
what PSI should I follow? The first gauge that shows the psi to be 110 or the tpms which shows the pressure to be 115. Or should I decrease the amount of air, putting the tpms as priority, in other words putting the psi to 110 down from the reading of 115?
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
