RCMAN46
Apr 24, 2015Explorer
I had a Pressure Pro for about 7 years.
When the batteries in my Pressure Pro gave out after 7 years I decided to try the TST system as I could get one for only a few more dollars than having the batteries replaced in the Pressure Pro.
Both systems work well.
I have noticed tow differences in the two systems.
1. Without an antenna extension or repeater the Pressure Pro has a longer range. Both will require an extension antenna or repeater if you want to monitor a utility trailer being towed behind a 5th wheel as I do.
2. On loss of signal it takes the TST system about 1 hour before it will notify you of the loss of signal. The Pressure Pro will notify you in about 15 minutes.
If I could go back a year I would have replaced the batteries and kept the Pressure Pro.
38,778 PostsLatest Activity: Jun 10, 2026
