My take is a little different in that the system worked correctly in that it alerted you. Now that fact the problem was the sensor is a bummer. However, I have had valve stems to start leaking.
Anything mechanical fails.Snomas wrote:
Took my MH out of storage the other day and the tires all checked OK on the TPMS monitor. Got home and 2 hrs later I drove off to put it back in storage and a low tire warning went off. My pass side inside rear dual read 82 psi. I took it to a truck stop and they pulled the tire and found it was ok. After re-installing the tire we put the sensor on and found it was leaking. $43 and it was the sensor!! Never had a problem w/tires before in 14 years of Motorhoming. I know the TPMS system is an important safety item!!! Just venting!
