BigMac's avatar
BigMac
TPMS w/ Airless Flexible Valve Extenders
I will be leaving shortly on an extended trip and would like to add a TPMS system for my MH and toad for protection and piece of mind. I currently use metal braided flexible valve extenders on my duals due to the impossibility of airing the inside tires without removal of the liner each time. The extenders are the airless variety. If I add a sensor to each extender, I've just changed it to an air filled extender. Is that a concern given it's not designed for that functionality? Should I change to an extender specifically made to hold air pressure in service? Thanks in advance for your replies.
  • JoeH wrote:
    Instead of messing with extensions that will eventually leak/fail, you should check into getting proper replacement valve stems This , Borg Tire Supply, is a source I've used. They are expensive and you have to dismount the tires to install, but they are much more reliable than the extensions
    Agree
  • JoeH's avatar
    JoeH
    Explorer III
  • No comment here other than thanks for the follow up regarding what you learned.
  • As follow-up to my question about the merits of the two types of rear wheel valve extenders (airless vs. air-filled) that can be used with a TPMS system, I called a TPMS manufacturer yesterday to see what they might say. While they said that their wireless pressure sensors will work with either, the specific statement regarding airless extenders was
    We've worked with these airless extenders before... To be honest, I do not like them. The metal rod that runs through the depressor commonly misses the tires valve stem (after a period of time being depressed) and gets jammed beside the original valve core causing leaks. We can work with them as we would depress the internal rod, and in turn depress the original valve core. You are exactly right though this would render the airless extender moot as it would constantly hold pressure. We usually work around this by offering a different extension (air-filled)...
    So I think that on the rear tires I am going to change over to air-filled. They have a robust depressor design that once fully screwed onto the tire's valve stem pressurize the extension and keep it protected via the metal braiding.
    If there are other comments out there, I'm interested to hear.
  • fcooper wrote:
    BigMac wrote:
    Dennis, thanks for your reply. Are they airless (i.e. an internal spring presses on the valve stem when filling the tire with air) or are they also pressurized in use? Who makes them?
    Thanks,
    Mike
    I think this is what Dennis is using:
    AML1 extenders
    Fred
    Yep! Made by Phoenix...Dennis
    Thanks,
    Mike
    AML1 extenders
    Fred
  • Dennis, thanks for your reply. Are they airless (i.e. an internal spring presses on the valve stem when filling the tire with air) or are they also pressurized in use? Who makes them?
    Thanks,
    Mike
  • These are the ones I use, six years and counting, with the TST 507 system. They've worked flawlessly...Dennis
  • Forget about getting an accurate temperature measurement with valve extenders. The extenders just put the sensors out in the air flow.
