horizon36
May 13, 2013Explorer
Your inverter will consume/draw about 55 amps to produce 500 watts out put. The 50 watt load will take about 5-6 amps. If you need 500 watts for 4 minutes that will consume approx, 6 amp hours plus the 50 watt load per hour will take another 6 amp hours. So, in order to cook for one hour you will consume approx 12 amp hours. So, it depends on your battery bank size and method to recharge them.
38,778 PostsLatest Activity: Jun 06, 2026
