sch911
Dec 27, 2016Explorer
Is the fresh water tank drain in the lowest point on the tank? If not re-position the MH so that it is. If necessary use wood blocks under the wheels, or park it on a slight incline. Generally there will always be a small amount of water left behind in the tank, which poses no threat when frozen. There should be a tank drain valve (right on the fresh tank), and also one or more low point drain valves. Have you run pink anti freeze through all the water lines, or at least have blown them all out with air pressure?
