tom3855wales's avatar
tom3855wales
Trailer Hitch excessive height
06 Fleetwood Flair Gas, body is swept up in rear to obviously prevent drag in situations where steep drives or driveways exist.
PROBLEM: Trailer hitch ends up being excessively high and ***** the trailer to a point where the rear end of trailer is a dragger.
I have used a drop down hitch w 2" reciever as a solution but it is not nearly enough. Have considered stacking a drop down reciever extension and a drop down insert. I fear the stacking method could be questionable since each marriage reduces the strength.
Puzzled....any thoughts on this issue that would be reasonable will be very much appreciated. Any suggestions others have used as a solution. Tks TomJ
