wny_pat1
Jul 10, 2013Explorer
GlennLever wrote:dougrainer wrote:
Gillig is NOT the people to ask about tow capacity.
ONLY the OEM RV maker can answer that question as Gillig just supplies the chassis/drivetrain. The OEM RV maker adds ALL the extra weight. You really need to WEIGH the RV with full water/LP/Diesel and THEN get a look at the Sticker on the RV and compare to carrying capacity. As another poster stated, you could put a 20k capacity hitch and beef it up, but that does NOT mean your RV can tow even 5k. Doug
This is the e-mail I got from Fleetwood
Glenn
Thanks for the email.
You should speak with Gillig about the hitch and chassis. They install and rate the hitch before we ever get the chassis.
GILLIG CHASSIS
P.O. Box 3008
Hayward, CA 94540-3008
Phone: (510) 264-5160
Fax: (510) 887-0981
Fleetwood RV
American Coach
800-435-7345
Glenn,
Doug is 100% right on!!! Actually by federal regulation, Fleetwood RV is the final vehicle manufacturer, and to change any weight specs, the coach would have to be returned to them for modification, inspection, and a modified vehicle spec/vin plate. You can install the new mount and trailer hitch, or have someone else do it, but doing so does not change the final manufacturers assigned spec weight/vin plate. It will remain at 5000 lbs until changed by the OEM RV manufacturer. There is more involved to assigning the GCWR and Tongue Weight of a motorhome than just the hitch rating, and Gillig has no idea what Fleetwood RV had done to their chassis!
It may be a beautiful coach, but best to find one already spec'ed out for your needs. There are lots of them out there that can do what you want without expensive modification.
38,770 PostsLatest Activity: Apr 12, 2026
