suprz's avatar
suprz
Trailer lights fuse box
On my 2006 Ford E450 super duty, where are the fuses/relays for the trailer lights (running, brakes, etc) under the hood, or under the dash? I don't have access to my owners manual, and I know these things have 2 different fuse boxes (at least that's what I think is correct)
  • suprz wrote:
    On my 2006 Ford E450 super duty, where are the fuses/relays . . . .
    Did you get your answer? Contact me if not.
  • Under the hood in the power distribution box, which will be just forward of the coolant bottle. If you're towing for the first time, you might need to add a relay to the "Trailer/B+" slot if you need constant power at the 7-way.
    The fuses under the dash are for the chassis lights.
