Has any one of you actually cheecked the plugs that connect the trailer to the motorhome, 80% of the time theese connectors fail due to the vibration of the cable, the screws that hold the wires are minuscule and most technicians do not solder the ends, they just jam the wires on and tighten the screw, this also has the added benefit of severing the wires and the end result is a loose wire.
Also take into consideration that theese connectors are open where the cable enters and water does get in, corrotion will take over and you loose connectivity, the other culprit is actually done by the person(s) vigorously either yanking on the plug and cable or moving up and dow and sideways on the connector and spreading the female receptacles in a manner that connections are either intermittent or non existing.
I start at the connector on the trailer and then on the tow vehicle, then the trailer and finally the tow vehicle, I solder the wire terminals and protect both connectors with liquid rubber to prevent any water or moisture from getting in, I have not had an electric failure between the RV and the toad in 17 years.
navegator
