Chris_B_in_MD
Jul 06, 2016Explorer
Transfer switch location???
Bought a used 2010 Jamboree Sport 28Y with only 14k on the odometer after having a 2002 Shasta Sprite & decided we needed a little more room. Really like the rig, but am having a generator problem in that it will not switch over to allow the generator to power up the "box". It has worked in the past, but not currently (no pun intended). Shore line works fine. Have read through the other posts & am pretty sure it's the transfer switch, but for the life of me I can not find the bloody thing. Any ideas where the little devil might be hiding? Yes, I have let it run for as long as 5 minutes with no results.
There's a junction box in the compartment where the shore line comes in, but that's just a 30amp female connector. Opened it up just to make sure.
Looked under the master bed where the convertor/fuse/relay panel is to no avail. Got a whole lot of wires in thar though.
Was an Auto tech for 40+ years so I have a little bit of mechanical/electrical ability.
Thanks!
Chris
Thanks!
Chris
