- MJD202Explorerwearenh, thanks the transfer box was there but now switch. Dusty can you email the image to me it would not allow me to see it....trz102@aol.com thanks
- wearenhExplorer.
ours is under one of the dinette seats, under a removable plywood panel
. - IAMICHABODExplorer III
Dusty R wrote:
Is there a receptacle where the shore cord is stored and will that cord plug into it ? If so that is your transfer, just plug that shore cord in that receptacle when you want power up your mh with the generator.
Dusty
It may look like this.
- Dusty_RExplorerIs there a receptacle where the shore cord is stored and will that cord plug into it ? If so that is your transfer, just plug that shore cord in that receptacle when you want power up your mh with the generator.
Dusty - MJD202ExplorerThank you for all of the replies. Mandalay, I did call the factory and they told me to look where the shore power is stored or in my rear storage. I did not see it in either place. I have been trying to find it very frustrating, there should be a diagram some place.
Thanks again! - Mandalay_ParrExplorerMine is located where my shore power enters my unit.
Jerry Parr - Hemi_RTExplorerOr you may not have one. Not all units equipped with a generator have a transfer switch, some are hard wired into the fuse panel with a flip flop breaker setup, some you have to plug the shore power cord into a generator output plug. If there is one it is usually near the distribution panel ( fuse panel )
- DrewEExplorer IIIOften it's attached to the back of the electrical distribution panel, or at least in that general area. That's just general info, not specific to your model.
You might be able to suss it out by listening for it clicking over to the generator (or back to shore power). - Mandalay_ParrExplorerI would call the factory and ask them.
- hotbyteExplorerI found mine by following the big wire from generator...
38,766 PostsLatest Activity: Jan 10, 2026
