wa8yxm
Dec 28, 2016Explorer III
This is not my problem.. But my solution may work.. My problem is putting gas into the motor home from a 5 Gallon Gas Container
I got some fuel line of the proper size from the local Marine Hardware and a Marine primer pump... I think you can figure out the rest
For your job you also need a quarter turn gasoline proof valve or a "Heamostat" type clamp enough to clamp off the discharge hose..
Use the pump to start the flow, when the 5 Gallon can is full clamp off and empty can into MH#2 Repeat
Option 2.. now this takes some knowledge
Most gasoline engines today the fuel pump is in the tank
You can cut and splice the fuel line between tank and engine, then apply 12volt to the pump and let it pump across.. NOTE I actually DO NOT recommend this as it is more dangerous.
38,763 PostsLatest Activity: Dec 05, 2025
