lc0338
Jan 06, 2017Explorer
4x4van wrote:
The problem with syphoning is that your target must be lower than your supply. An electric fuel pump will allow you to go directly from one to the other without having to syphon into a gas can and then pour the can into you final MH, regardless of the height of each.
Doesn't have to be. Insert 2 hoses stuff rag in opening and use air compressor to apply the force. More force the higher it goes.
38,763 PostsLatest Activity: Dec 05, 2025
