MDKMDK wrote:
theoldwizard1 wrote:
MDKMDK wrote:
The best answer appears to be "no, not easily or safely".
If there is NO LIQUID PROPANE INVOLVED, it IS easy and safe.
Propane inside any storage tank is primarily liquid under pressure. Opening the valve reduces the pressure and allows it to become gaseous.
Also, check your CAPS LOCK. It seems to be malfunctioning.
The change from liquid to gas is caused by the LPG boiling, not it’s containment or lack thereof.
If it was colder than -42 degrees you could carry it around in a pail like it was water.
