rgatijnet1 wrote:
FIRE UP wrote:
lj2654,
As has been stated, there is no test that the average motor home owner can do to determine if you have Dexron or Transynd. An oil sample sent to a reputable lab can tell for you. Now, if you're relatively sure you've got Dexron, and, want to change to Transynd, then here is the procedure direct from a member on here and, IRV2, who was instrumental in the development of test procedures for many Dexron products and, synthetic products including Transynd.
This is a fairly expensive way to do it but, it's the way, according to him, that many of the service centers do it.
1. Drain existing trans fluid completely and DO NOT CHANGE FILTERS AT THIS TIME!!!
2. Replace with Transynd an equal amount of fluid.
3. Drive your motor home for a minimum of around 30 - 45 minutes, letting it shift as often as possible.
4. Drain all that fluid out, remove filters.
5. Install new filters and, replace with NEW TRANSYND again to correct level.
You are wasting money by replacing filters on the first change. By only driving around 30-45 minutes, that, according to him, is plenty of time the first round of Transynd to start to replace the exiting Dexron. Then, with the second round of Transynd, the experts say that, the tiny bit remaining Dexron, will have no effect on the operational characteristics of the new Transynd. And, after you've done the second round of Transynd, you're good for right at 100K miles before needing another trans fluid change. I'll try and find his member user name and repost so you can see all he has to say about Transynd and other important data on other fluids including Dexron.
Scott
That is all good information and spot on. The only thing that I would add is that you are good for the long extended fluid change, IF, and this is a major IF, you do not overheat the fluid. If during a long climb up a steep mountain road, pulling a toad or trailer, and you seriously overheat the transmission fluid, then the life of your Transynd will drop to maybe only a few thousand miles. On some transmissions there is a sensor to monitor transmission fluid temperature. I have a sensor on my Allison transmission and I would know in an instance if I overheat my fluid enough to affect the fluid life.
This caveot is one of many reasons to do an annual sample test of your fluid.
