wolfe10
Jan 06, 2015Explorer
Let's rule out the IGNITION SOLENOID. Turn the key on. Do the rest of the dash warning lights illuminate? Does the dash HVAC fan operate (or any other item that only operates with the ignition on. If not, suspect the ignition solenoid. If not, move on.
To troubleshoot the Allison shift pad (assuming the ignition solenoid tests good), contact this guy-- he is the expert and repairs shift pads and Allions ECU's: 866 439 9779 John Kopalek. www.transmissioninstruments.com
38,769 PostsLatest Activity: Apr 24, 2002
