map40ExplorerMar 02, 2019Transmission oil change due to time?I'm buying an Alfa with a C7 and an Allison 3000. The tranny had an oil change 4 years and 25k miles ago. Do you change the trans fluid due to time?
twodownzeroExplorerMar 02, 2019If the trans pan has a drain plug, I would drain and refill the pan every time you change the oil.
Related ContentChanging transmission fluidDifficulty timing a 1995 Chevy 454ciChanging transmission fluidTime for changeAllison transmission fluid change interval.
