map40
Mar 03, 2019Explorer
Bruce Brown wrote:twodownzero wrote:
If the trans pan has a drain plug, I would drain and refill the pan every time you change the oil.
Thats a bit excessive, isn't it? :E
If the filters last 150k, I don't mind the extra expense, and this would far exceed the requirement it is far less work, right?
38,778 PostsLatest Activity: Jun 10, 2026
