jimsretirementf's avatar
Feb 20, 2016
Transmission oil cooler
HI All, I have a 1989 Itasca class C motorhome, it has a 460 Ford motor with auto trans. I had the air conditioner in front evacuated and new refill fittings installed. In front of the radiator is the air conditioner coils and in front of that is the transmission oil cooler, all blocking air to the radiator. The motor gets very hot when using the air. I am looking for an remote transmission oil cooler, can anyone suggest the best one to use. I would be looking for size, cfm,cooling rows and brand. I would like to mount it under the floor close to the trans. Or is there another way to fix this problem.
Thank you for your help.
Jim
