time2roll
Aug 17, 2019Nomad
I recommend swapping the fluid to Mobil 1 synthetic. Did the engine temperature gauge move? Possible the engine was running at the top of normal due to a worn fan clutch contributing to the transmission heat.
If you were in low gear the torque converter was not locked and was building a lot of heat. If you do this again let it idle in neutral 5 or 8 minutes at the top before you shut it off. OK to pull off half way up and let it idle and cool a bit.
38,782 PostsLatest Activity: Aug 23, 2026
