Paleo's avatar
Paleo
Transmission Rebuild cost?
So I picked up a 96 Winnebago Adventurer "QCG32WQ" on the chevy p30 chassis this past weekend on Craigslist. I test drove it and it seemed to drive fine, no major issues other than that u had to fiddle with the gear shift when in reverse to get the auto park brake to disengage.
The seller did say to me however that in the nearly 20 years he had owned it, on a dozen or so occasions, the RV would not want to come out of 2nd gear. He said he found if you stopped, turn the rig off for 10 minutes, then restarted it, it always went away and would go for another many thousands of miles b4 it ever repeated itself. He said he could never get a dealer to replicate the issue so there was no fix for it. It didn't do this when on the fairly lengthy test drive. For me it shifted just fine.
So here we are 2 days later and I'm taking it to a shop to have some minor things taken care of (oil change, have the auto park brake looked at, wheel bearing repacked, etc) and sure enough, it seems to not want to shift out of 2nd gear. I didn't have the time to stop and let it sit for 10 minutes as he mentioned, but is this normal for this model, and if not, am I looking at a shot transmission? If so, any ballpark figure on the rebuild cost for this rig?
Any input would be much appreciated.
  • When my tranny failed, I had a choice: The shop could rebuild what I had...or get a "re-manufactured" unit from JASPER.
    "Re-manufactured", I'm told, uses no "old" parts...new ones are installed and that is the main difference between "rebuild" and "re-manufactured".
    I opted for the JASPER re-manufactured.
    Cost$2300 + labor = 4 grand.
  • bump for rebuild costs, still havent heard anything from the repair shop
  • rgatijnet1 wrote:
    If it does need transmission work it is probably a typical GM 4L80E/4L85E transmission which are available all over. $1200 or so should get you a rebuilt one, plus labor to drop the old one and install the new one.
    and how many hours of labor does that take on one of these rigs approximately?
  • If it does need transmission work it is probably a typical GM 4L80E/4L85E transmission which are available all over. $1200 or so should get you a rebuilt one, plus labor to drop the old one and install the new one.
  • Great, thanks for the replies, so teh fact that it drives normally other than this "hiccup" is maybe an indication that its something other than a major transmission failure I guess? Sorry, I'm really new to RV's but I'm a pessimist by nature so my first thought is that its the worst case scenario, lol.
    anyone ever had to pay to have a rebuild btw, just in case it is that bad?
  • I would have your mechanic pull the transmission pan and inspect the pick up tube/trans filter. Sounds like stuff might be getting sucked up into the pickup and clogging. When it is shut off, the obstruction might be falling back into the pan.
    Just a thought.
    Good luck
  • My first question would be, when was the transmission fluid changed?
    I have a 96 Southwind on the P30 chassis. I've never had a transmission problem.
    My AutoPark sometimes acts a little funny. Especially when it's cold.
    It takes it's time releasing.
    Other than that, no problems.
