dodge guy wrote:
RJL wrote:
dodge guy wrote:
It should have a drain plug in the pan. What I do is change the fluid every 25k miles and the filter and fluid every 50k. So basically fluid every 25k then the filter skips a change. With the drain plug there is zero mess.
How many miles on the trans?
32,000 on the trans. We tow our Jeep though and have done many 2500 miles trips towing it. It's time, I think to change out everything.
No problem. I agree to change it all. I also tow my Explorer. I work it hard, so keeping he fluid fresh is the simplest thing you can do. I just wish I could monitor the trans temp other than the dash gauge. I could on my Excursion, but my monitor doesn't give you that PID on a 2011 chassis.
Get a scan guage.... allows you to monitor many parameters, including tranny temp. I had one on my f-53 based MH.
