rvinit
Nov 09, 2015Explorer
Transmission slipped temporarily(?)
Hi all,
I've put about 500 miles on my '94 HR Imperial with 60k miles and the Ford 460 engine.
I've only seen my transmission temp gauge move above 100 degrees one time, and it was only slightly. When I put the key in the "on" position, I see the needle twitch a bit... but here's what happened:
I towed about 60 miles the other day (little Chevy Sonic on a car dolly) to my home for the next few weeks. Parked for about 20 minuteo, did some check in and walked around, disconnected my car and trailer, then drove across the street and backed into my space. I turned the engine off and decided I wasn't happy with my placement.
I started the engine, dropped it into reverse, nothing. Revved a little, nothing. Switched to drive, nothing, neutral, back to drive, revved to about 2500 and heard the trans catch and I started moving forward. Threw it in park immediately. Noticed the smell, opened my driver door and saw white smoke rising up. Engine temp around 230, trans gauge still showing under 100.
I let everything cool down and inspected for leaks, can't find any evidence of one. Got engine up to temperature two days later and checked tranny fluid - it's clean, red, and filled appropriately. I put the home in drive and it engaged immediately and pulled forward. Reverse was the same.
I'm concerned now because it's acting as if nothing ever happened and I've done nothing to figure out what this could have been. Any suggestions about where to start? I'm going to pick up another transmission gauge tonight to test with, just to be sure...
