twainharteartisExplorerJul 22, 2014transmission was leaking but not now?I have a 1997 34 ft. Damon Intruder that has the E40D ford transmission. It was licking trans fluid from the bell housing. I thought it was the front seal. But I moved it the other day so the tow truc...Show More
George_HExplorerJul 23, 2014IF it sat long enough for seals to dry out, possible that use will soften seal and stop leak.BIG IF
Related ContentNautilus P1 has leaking connectionsAllison Transmission leakTransmission leaks when towingUpdate on transmission leakLippert faucet leaks, replaced with Moen
