twainharteartisExplorerJul 22, 2014transmission was leaking but not now?I have a 1997 34 ft. Damon Intruder that has the E40D ford transmission. It was licking trans fluid from the bell housing. I thought it was the front seal. But I moved it the other day so the tow truc...Show More
IvylogExplorer IIIJul 23, 2014Not uncommon if you overheat it, it will leak oil. Add a oil cooler and you should get several more years out of it.
Related ContentNautilus P1 has leaking connectionsAllison Transmission leakTransmission leaks when towingUpdate on transmission leakLippert faucet leaks, replaced with Moen
