avanti wrote:
If you have an inverter, you are probably better off setting your 3-way to 120VAC while driving. It may be less efficient, but you don't really care while getting power from the engine alternator, and most 3-way refrigerators perform much better on 120VAC than on 12VDC. I don't know why you would want to use propane while driving.
I do agree that if you have a choice, 12VDC compressor is the way to go (and I've had both).
I don't see an inverter listed in their electrical specs for a Travato. They list a converter. If there is an inverter it may be a small one designated to run a TV off the batteries when off shore power.
