erip wrote:
With the technology of solar and the availability of 12V compressor fridges, why would any manufacturer use an absorption fridge, auto ignite or piezo ignite, in this day and age, yet thats where we are. The only perfect RV is one designed exactly by the person using with top quality materials. Sadly the rest of us are not Romney rich, so we research and then go with the closest fit possible and try to enjoy what we own.
I wish I were Romney rich. I've researched and selected the closest fit possible twice already and I thought at the time I did all right. All it gets you is a frustration and longing for the next RV, IMO. So, not factoring the practicality of the cost or ROI I decided at least one more time to see how close I could get to an optimum RV. I do only want a Class B. I'm not looking for anything bigger. I suppose I could have spent more and joined the ranks of the Class A owners. That will never happen. My design aesthetic sensibilities simply would not let me to ever consider a Class C.
You're changing the argument but I don't quite understand. Why are you not then castigating Winnebago for putting in a 3-way or not giving you an option for a compressor frig? Also, it doesn't change the fact the Travato is using a generation old technology most every other company has moved on from for 3-way refrigerators. You were the one that pointed out the drawback in not being able to restart the refrigerator while driving down the road when it went off.
Anyway, there is a very good reason for a 3-way. If you have propane on board your propane would be a very expensive proposition if you didn't take advantage of it. Other than a half hour to heat hot water our propane only goes to running the refrigerator on most days. The absorption DC side is a battery eater. That leaves you searching electrical hookups.
