Bill_Satellite
Mar 26, 2014Explorer II
allbrandauto wrote:
going to install traveler sat. dish for my 2007 Fleetwood bounder do I need to buy the reinforcement plate or is this over kill
I would consider it to be over kill. It's called a thin roof mounting plate and that's really its intent. If you have enough structure in your roof to walk on it and get a good bite from the screws then you don't need the plate. Be sure to put a thick bead of caulk (Dicor) under the base ring and then screw and caulk around all edges and screws.
You will love that antenna!
