sdianel wrote:
we have camped in 10 degree weather with no problems. Fill the onboard water tank, unhook the water hose from the RV and dump tanks when you have water that is not frozen. Our bays are heated, if yours are not, you can use a light bulb as Executive said. Make sure you have plenty of propane for the heater. Make sure you ask the campground if the water will be on. Many campgrounds either close in the winter or turn the water off. Be prepared to stay as long as necessary so you can leave when there is no snow or ice on the roads. That area is very popular during the holidays. Reservations may be necessary. We like River Plantation in Sevierville as home base.
Thanks SDIANEL, we currently have reservations at Bear Cove and this will be our base for 3 night. Then we will be stopping in Nashville for 2 nights and Memphis for 2 nights. According to my wife the campground will have water. thanks for the light bulb trick will the light bulb be enough to keep the black and gray tanks from icing over or will i have to use some sort of antifreeze.
