aaronmtExplorerJun 18, 2019Tread design?We have just picked up our first Class A,it's a Damon Challenger 348w.We have been long time truck campers.We tow/launch a 5500lb boat with our current set up(4wd dually) with zero issues.The coach we...Show More
carringbExplorerJun 19, 2019You probably would be served well by a closed-shoulder moderate-block tread pattern. Open shoulders will decrease stability.A really popular on-road tire in the NW is the Toyo M154. If you use the coach in the winter, then Toyo M920 is a little more aggressive.Stay away from the cheap imports like Double Coin. I've never had one blow out, but traction is terrible and they never balance.I also like the Continental HSR, but they are pretty tough to find in the 245 size (225's are all over).
Related ContentSlide design by Grand DesignTreads closed.tread patternTire tread wear.Tire tread depth
