Racorman
Nov 21, 2015Explorer
Racorman wrote:Canadian Rainbirds wrote:
Go with the Trik L Start. Or the Amp L Start (15A) perhaps increase the wire gauge for the longer than normal runs. Esp if the chassis batteries run things that you will be using a lot such as the dash sound system, steps . . .
Racoman: I'm jealous of your solar. We have a 32' Itasca DP and 420 Watts of solar. How did you find room on the roof for 900 W on a 30'? :h
I used residential solar panels and also removed my rear air conditioner to make it work. I have (3) large residential panels on the roof. They are 300 watt 36 volt panels. I needed that much solar to charge my (6) 6 volt batteries.
One air conditioner seems to work just fine for us and it gave me enough real estate to put 2 panels on the rear of the roof and one toward the front of the roof. I just installed the Trik L Start. Easy install and it works like a charm.
Thanks all
