BB_TX
May 17, 2017Nomad
It is possible the GFCI outlet has started to fail. It does have a sensitive circuit to compare current flow thru the hot and neutral lines, compare the two, and trip if there is even a very small difference between the two. Before I got too far into checking every individual circuit, I would replace the GFCI outlet. Inexpensive and easy to replace.
