luvlabs
May 21, 2017Explorer
RVs are constantly causing house/garage GFIs to trip. Why? RVs use a different grounding scheme to account for generators, inverters, and other sources of A/C power. Your RV is protected by GFI outlets and you do not need to plug into a protected outlet. Install a power panel (50 amp or 30 amp plugs with no GFI) and nothing will trip. 30 amp is the easiest as it only requires a single breaker and 10 gauge wire to wire to code.
As an alternate, plug into a non-GFI outlet in your house.
