pianotuna
May 21, 2018Nomad III
If a diode isolator is in use replace it with a relay.
If a relay is in use, check the fuse for continuity. If the fuse is good, then it may be that the contacts are burned.
38,782 PostsLatest Activity: Sep 10, 2026
