JRscooby
Nov 03, 2021Explorer II
Problem will likely be found when you take the connector apart.
In general, my go-to for fuse blowing is a amp meter that can measure when laid on a wire. (Snap-on, early '70s) I use a turn signal flasher to replace the fuse, follow the wire with meter. when Needle stops jumping, just passed the short.
