svjim's avatar
svjim
Happijac trouble shooting
I have the remote control happijacs on my Adventure TC and one of them does not work. I suspect a possible short in the wiring from the controller to the jack. I have verified that if I switch another jack to the same port that the failing jack is on that the switched jack works. Also, the failing jack does not work on another controller port. So my conclusion is either the head is bad or there is a short or crimp in the wiring. I have a couple of questions for someone knowledge in the jack's functioning..
1. how can I test that there is actually current running through the wiring to the jack head. I think I should be able to do that at the external 'box' where the wiring exits the camper and is connected to wiring to the jack head. If so, what should I look for?
2. If there is current flowing at the box, how can I check that it is actually getting to the head. (i.e. flowing through the wiring from the box to the head. Is it possible to do that without removing the head itself?
3. OK, the camper is not in the Truck bed, so If I have to remove the head, can the jack itself be locked or am I going to have to manually raise the jack and put it in the truck bed?
Thanks
Jim
