Gridley's avatar
Gridley
trouble with ac outlets in Allegro Red 33
My RV was connected to shore power. I was vacuuming with a shop vac plugged into a GFI outlet in the RV. Then the power to the vacuum just stopped. Nothing in the GFI outlets.
The non-Gfi outlets were still working. All of the breakers were fine.
I thought it might be the GFI outlet so I replaced it. Same result.
After trying everything I could think of, I happened to turn off the shore power. Now not only do the GFI outlets not work on the inverter the non-GFI outlets don't either.
I am confused. Any help would be appreciated.
Thank you,
Tim Henry
