We_Cant_Wait
Aug 14, 2014Explorer
Sometime you can still get a wheel weigh at a CAT scale. Look at the scale and if there is no rail along the side and the ground there is flat you can drive on the scale with the right side tires OFF the scale, this will give you the left side tire weigh. Then do a re-weigh with the whole MH on the scale for a total weight. The subtract the first weights by axle from the gross weights this will then give you the right side weights.
38,776 PostsLatest Activity: May 15, 2026
