j-d
Aug 14, 2014Explorer II
Get a CAT Scale weight NOW and fine tune it later. Unless your coach is really odd, or loaded very strangely, you won't have what Michelin wants to check for with four-corner weights. Namely, an Overloaded Corner.
The LT225/75R16E tires on most C's will support 9880-lb as rear duals. Michelin would specify that for "Truck" weights but they've found RV's more likely to be loaded unevenly. Say your rear axle is rated 9500-lb, which still calls for 80-psi at full rated load. FORD would like you to not go over 4750 on either side. Michelin would be happy up to 4940. Corner Weights (Michelin's RV chart) help you make sure that an Axle within weight rating is not overloaded on one end. But you still inflate BOTH ENDS to the higher corner weight. Michelin makes that clear.
Get Axle Weights and you've done more than most RVers. Adjust weight based on that and you are TPE. Tire Pressure Elite. FRONT tire pressure has more effect on Class C handling than you'd ever imagine.
38,774 PostsLatest Activity: May 13, 2026
