RayChez
Jul 13, 2013Explorer
I never had a blow out with the Michelins XRV, but right at five years they had cracks all over the side walls to make any person with common sense to change them out. The thing was that they were one month past the warranty and Michelin would not even pro-rate them even though the tread looked new.
So my point is that if they had UV additive to the rubber, it sure did not work on mine.
The ride on your coach is determined by what type of suspension you have on your coach. There are good and then there are some that will ride too stiff, does not matter what kind of tires you have.
Look at the tires on commercial buses and you will change your mind about using at least H rated tires.
Also! Have you ever seen the damage of a blow out?
