GTO66's avatar
GTO66
Explorer II
3 years ago
Truck tires
I've had very bad luck with tires on my dually due to separation issues. I'm only getting 15k to 20k before this happens and 3.5 to 4 years. I only have the camper on the truck about 3500 miles a year, and the truck is always in the garage if the camper is off which is most of the time. The camper is a 2000 alpenlite 1150 limited, and weight is around 4800 lbs ready to travel. Sticker on the camper states 3600 lbs. I've owned this camper since 2004 and had the rig on the scales back then. I remembered I was under the capacity then however I'm unable to locate the form now. I plan to have it on the scales on my next trip, but thats not till august. The tires have all been E rated and are run at the 80 psi cold while carrying the camper monitored with a TSP system. The first set were BFG commercial. The second goodyear wrangler. I have a lesser name brand on the front WEstlake that are 5 years old and appear to be wearing well, they were the only one available at the time I had a failure while traveling. Wondering if others have had issue and what brand seems to be working for others.......Thanks
