- RayChezExplorerI third that Toyo tires are excellent tires for coaches. Country Coach used them on their Coaches for some years. And I would rather have that h rating and not worry about zipper blow outs that Michelin had with their XRV tires.
I have had both on my coach and it rides smooth with either, no difference.
As to the cupping mentioned, that is not a tire problem,it is a problem with tire bounce caused by worn components, probably shocks. - bluwtr49Explorer II
wa8yxm wrote:
The major difference between RV rated tires like the Mitchlin XRV (And yes there are such things) and Semi Truck tires is the rigidity of the sidewall.
The RV tires are a bit more flexible so as to give a softer ride.
The Toyos I took off had a very rigid sidewall and the replacement Hankooks were quite pliable so I'm not sure that is a universal truism. - wa8yxmExplorer IIIThe major difference between RV rated tires like the Mitchlin XRV (And yes there are such things) and Semi Truck tires is the rigidity of the sidewall.
The RV tires are a bit more flexible so as to give a softer ride. - orchardhillExplorer2oldmen, had the same thing. Bought 6 about 4 years ago, got a bfg recall, only 4 needed or were replaced.
- Sully2Explorer
rgatijnet1 wrote:
The only companies that make tires that are specifically marketed as RV tires are Michelin and Goodyear. Both of these companies put extra compounds in their formula to resist UV damage to tires that just sit in the sun a lot. Other than that, I would suspect that truck and RV tires are close to identical.
YEP! - D_E_BishopExplorerA bad front end alignment damaged the TWO front tires. Happened to me twice. Old p32 chasis is so wibble, wobble you don't notice all the alignment problems you might have until it's too late.
- 2oldmanExplorer IISince OP hasn't returned, anyone care to speculate as to why only 2 tires?
- Don_DonExplorer
deandec wrote:
I would rather have Bus tires than RV tires.
Does anyone make such a thing?
Continital - steveownbyExplorer
Michelin makes the X Coach X, which is marketed as a bus/motor coach tire. - Captain_HappyExplorerThere also load ratings on tires. Like "H' or higher. Big truck tires period.
38,768 PostsLatest Activity: Dec 18, 2017
