Ro646a's avatar
Ro646a
Explorer II
Jul 24, 2017
Trying to clean my rear radiator
I have an 05 Winnebago Journey diesel. Everything is working fine, but at sustained speeds of 65 mph or over, the water temp goes up to 214 degrees, so I stay below 65. I'm assuming that the radiator needs cleaning.
I have done some research on how to do this, and know that it must be done from the front of the charge cooler. My problem is that the fan blades are so large that I can barely get my sprayer wand in there to apply solvent. I'm afraid if I spray the solvent in there that I won't be able to get enough water in there to flush it out after the solvent is applied. I tried shooting water through the radiator from the back side to see if I get any significant flow through the fins, but it appears that the water never makes it as far as the charge cooler. I'm applying water under city water pressure with a nozzle on the hose. Can anyone offer any suggestions before I try to do this?
Thanks
