tenbear
May 15, 2013Explorer
My battery disconnect switch is down by the door. It is a rocker switch, press the top to connect the battery, bottom to disconnect it. Since I don't have a Jamboree, yours may or may not be the same.
When you say the lights work do you mean the coach lights? Usually if the battery disconnect switch is set to disconnect the coach lights will not work.
You did install the batteries with the right polarity???
38,769 PostsLatest Activity: Apr 03, 2026
