Bordercollie
May 16, 2013Explorer
On our 2004 Fleetwood Tioga 26Q there is a control panel with rocker switches and LED's showing what's on or off (etc). One switch is marked "Aux Battery" or something like that. When you rock this switch to "on" you should hear a click coming from where the house battery compartment is, probably under the entry step.If you don't hear a click, the relay device may not be working/stuck, or the house battery may be discharged/dead.Sometimes rocking the switch will get the relay to work, then the house battery may provide power to your 12 volt stuff. There may be a separate switch for the slide(s). Call Fleetwood or Fleetwood dealer for assistance.
Get as smart as you can be about 12 volt DC and 110 AC power and charging systems including how to proactively keep house and engine starting batteries charged when rig is not in use.
38,769 PostsLatest Activity: Dec 31, 2017
